spindle won't start EF4 error
Yasakawa V7-4X
Buddy Alpha
Anyone have time and knowledge?
Spindle drive was working fine, now won't start.
Drive Error Code: EF4
All Parameters set correctly. (except n024, which shows RPM/1000; which is correct)
The n053 setting is 4, which is normally closed (NC), and is the Multi-function Input Selection 4 (Terminal S4).
EF4 "Causes and Corrective Actions" states "Check the external circuit (sequence)". This is the brown jacketed, blk and wht pair that comes from the controller.
With the key ON, there is 24.74vdc across the blk/wht, which maintain NC condition in V7. With SB3 control software properly prepped, I push "Start" button, and and the voltage drops out (assume appropriate - should let switch in V7 go to Open).
So, I assume the EF4 is saying the voltage/amperage is "ugly" (parity problem?) coming from controller?
Don't see that I'm able to reset, except by changing n053 to 5 (factory, allowing reset); I did, it then showed the RPM, but still no joy. Set back to 4
Other observations:
on main controller board, the LEDs at "Spindle 1", "SR1", "SR2" are yellow.
I APPRECIATE ANY KNOWLEDGEABLE FOLKS OUT THERE!
thnx,
Denis
