Pinion gears and need help
Its time to change my gears. Once I tried to remove the pinion gear on the z motor I found it impossible to break the blue locktite on the allen nuts. I applied so much heat that the gear was smoking (not sure of the temperature). I even broke one nut and have tried 3 different times.
Should i use a propane torch for more heat?
Should I use a soldering iron for more pin point heat?
Should i try and soak the gear in acetone?
I dont like the idea of drilling out the nuts but would that work?
I am open for any suggestion that will work.
