I've been doing a lot of indexer work in the past few weeks. I'd like suggestions on what to do for dust collection. Currently my dust collector is called "the floor" and "the table".
Attachment 2916
Attachment 2917
Attachment 2916
Attachment 2917
I built a custom table with a "trough" in it for the indexer, so I've just added thin ply to the sides of the trough to box it in. You could probably do something similar to catch most of the dust.
My stock dust collector foot just doesn't work at all on the indexer. If I was cutting lots of pieces that were the same diameter, I would consider making a custom foot.
I've used this 4 inch T wye , you need to enlarge the end to fit on router , works really well with indexer
Attachment 2918
Attachment 2919
Attachment 2920
You need to almost cut it in half , and add small filler in bottom
I had made a drawing of a trough like setup like scott talks about but coouldn't find the original pic, but here is what i was talking about.
The problem i found with any kind of dust foot was you couldn't create a seal around your project to get good suction.
Attachment 2921
I'd probably use a trough with a floor that slopes to a low point in the middle. At the low point I'd have a dust collector intake with a gate to close it off when not using the indexer.
A picture is worth a thousand words....
Attachment 2922
(but in this case, probably only 50 words)
-- Pat
