I R2 building a robot.
I thought it was time to force myself to learn some techniques I haven't used on my ShopBot. I have always wanted a little shop helper, too...so I found some plans on the internet and joined a couple groups to begin work on building my own little R2D2 droid.
I'm planning on leaving this one static, so I won't be adding motors and remote control ability or anything. He'll light up and beep, though.
Thus far, it's 100% cnc, including the frame, 3d parts...all of it.
I have pulled most of the 3D parts from a very good sketchup model.
I began with some vectors to cut out the leg shapes:
http://3.bp.blogspot.com/-2QQPqNPHQ3...600/r2legs.jpg
I also started carving some 3D parts for the legs.
http://3.bp.blogspot.com/-NGvTHFUogD...ggreeblies.jpg
Sometimes, to test how something would work or carve, I've run a test in pink foam. Once I know it's ok- I carve it in scrap HDU (I own a sign shop) or pvc or wood.
http://4.bp.blogspot.com/-foGxfH_qPZ...uepartfoam.jpg
Next up:
I built a frame from wood for the body. The plans for that frame came from a the R2 builder's club...a guy named Mike Senna created them, but I had to vectorize those plans to use on the Bot.
http://1.bp.blogspot.com/-8ha7b7krsR.../R2withleg.jpg
The body is wrapped in pvc "skins". There is an inner skin and outer skin. Here is a picture of the inner skin on front. It was done in 1mm pvc.
http://4.bp.blogspot.com/-SrOzpN5k_X...1600/skin1.jpg
http://3.bp.blogspot.com/-2reBQVbu_j...1600/skin2.jpg
Over the weekend, I attached all 4 skins, and carved up several more parts in 3D. You can see that I have several brands of HDU in different sizes. I'm using scrap and keeping my cost very low on this fella.
http://3.bp.blogspot.com/-hLofaXqZ18...00/r2skin4.jpg
http://2.bp.blogspot.com/-xJpy19GbAi...bodypieces.jpg
Now I'll finish the 3D parts for the body (just a few to go) and then start work on the triangular feet. All in all, it's gone pretty smooth. I work on it a little bit each day between jobs.
That is too cool . how long has it taken so far? cant wait to see it completed
That is so cool! I can't wait to see the final poduct. What a great sample to have in your office to show customers 'it ain't just wood'! Great job and thanks for the photo essay. I appreciate your work as I have TRIED to use 1mm sintra and I just can't get it to work for me, so 3mm and 6mm is what works. This month I am working on my vacuum system so when done I will try again with the 1mm stuff. Great thread thanks. Russ
Doug,
That is as nicely crafted as any cabinet i've seen guys build on here:D
My question is....do you have any kids? because i can see you might have enough room for an average 6 year old to fit inside!:eek:
good job:)
Thanks!
I have been surprised at how fast it has gone. I've been working on it just under a week...not full time. A piece here and there. I think it's going to slow a little once I get to the dome...but we'll see.
My 10 year old won't fit in it, but she has told me that I better keep it once it's done. I'm kind of notorious for giving away projects, and she wanted to be sure this one stays here.
Absolutely brilliant project Doug. Look forward to seeing it finished.
Really nice, make sure to keep posting.
That is very cool! Lots of complex parts from the looks of things...
AJC
