All,
Here a the latest BETA shoplink for Ecabinet:
http://order.ecabinetsystems.com/upd...ink1-0-21.aspx
All,
Is this a new version of the ShopBot Link for eCabinets? Could you tell us more about this version please? What are the changes from v1.0.20?
I don't see any mention of it on the eCabinets site.
http://www.ecabinetsystems.com/ecabinet_systems_updates.htm
This is a Beta version, 1.21 2.
Items contained:
• Pocket screw construction is now supported. See the manual section Tooling->Operation Tool(s) Setup. (ADDED)
• Option to try and keep flip operation parts together in nest. The option is in Nesting Parameters. (ADDED)
• 2 tabs not working correctly. (FIXED)
• Off-fall not created on Added Sheets correctly. (FIXED)
• Scrap Recovery not obeying grain setting. (FIXED)
• Grain grouping across cabinets not working. (FIXED)
• Random unwanted cuts on tenons. (FIXED)
• Minimum feed rate not used with Climb cut designated. (FIXED)
• Pocket cuts going outside boundary when cutting spiral inside-out direction. (FIXED)
• Batch order from eCabinet Systems not maintained in Load screen. (FIXED)
This is really interesting and I'm very appreciative to TWC for taking the time to upgrade the link. I was hoping for an upgrade, now to test and see if everything works as it should.
All,
Just checked the Ecabinet System and they officially version 1.21.2 for the Shopbot link. You can find it here.
