Practically brand new Shopbot Tools Desktop with 1hp Spindle
Purchased brand new in January, 2016
US (110V)
XYZ Movement: 24" x 18" x 5.5" (609.6mm x 457.2mm x 139.7mm)
Cutting Volume: 24” x 18” x 3.5” (609.6mm x 457.2mm x 88.9mm) [e.g. with 2" long cutter]
Footprint with Spindle: 39" x 32" x 30"(h) [Spindle VFD fits to right side of gantry]
Weight: 102 lbs [without spindle]
Frame: Welded aluminum, precision ground guide surfaces
Deck: Aluminum "T" slot extrusion [removable]
Linear Bearings: Fully supported precision linear guides and blocks on each axis [THK]
Drive System: Motors with integral, precision-coated lead screw with anti-backlash technology on each axis
Integral guard and dustskirt
Cut Speed: 4 inches per second (100mm/sec)
Jogging Speed: 6 inches per second (150mm/sec)
Resolution: 0.00025” (.00635mm)
Electrical System Requirements: 120V @ 15Amps [router or spindle]
ShopBot Control System software to run your CNC
Each new ShopBot comes bundled with two powerful software programs to create CNC projects.
Includes simple, quick-start set-up guide
When it comes to quality, the difference is in the details.
Like all of our tools, each ShopBot Desktop is built here in the U.S. in our Durham, North Carolina headquarters. We use the highest quality parts so that you can count on the tool to perform for you for years to come:
The ShopBot Desktop has a welded aluminum frame and steel rails, giving this tool the heft and rigidity to do real projects. Others may use plastic parts in their smaller tools — ShopBot does not. We don't cut corners!
The ShopBot Desktop uses the same control and software as our full size tools. It runs ShopBot software and ships with the ShopBot Design Software Suite so it’s fully compatible with other ShopBots and all of our ShopBot resources such as training, projects, and forums.
If you're new to digital fabrication, you'll find that the ShopBot Desktop has resources to help you. The Desktop's quick set-up, starter projects, and new ShopBotEASY interface will help you get to work on day one.
Customer support is available 7 days a week, including evenings, from our Durham headquarters. If you're just starting on the CNC learning curve or you've been "fabbing" for years, we have a knowledgeable, friendly support team that's ready to help.
As one of our long-time ShopBotters has told us, "On a scale of 1 - 10, ShopBot gets a 30 for customer support."
$6,000
(844)697-5286 ext 700
brady@iplatoon.net
Attachment 29039Attachment 29040Attachment 29041Attachment 29042
