5 Attachment(s)
Design Idea for Teachers - Nailbox
Dear Nick
(This may turn out to be a duplicate post)
Again welcome to the forum and good luck with your new shopbot, I remember the feeling well, excited and nervous at the same time. Remember if in doubt use the Preview Mode.
As for design ideas. One project I did with my 1st year students was a nailbox (you might call it a caddy) out of 9mm Birch Ply.
In order to keep the joints tight, I would get one of the more advanced students to measure the exact thickness of the 9mm birch plywood and then using SketchUp resize the DXF to match.
The attachments
NailBoxCRV.zip - contains a Partworks 3.5 file
NailBoxSKP.zip - SketchUp V6 File
NailBox.DXF
PartworksScreenDump.PNG - shows the toolpaths
The handle is in two 9mm pieces glued after machining to make 18mm
The CRV file is for Partworks 3.5 (vCarve Pro Shopbot edition). I had to remove the toolpaths to reduce the file size for posting, but the cutters used were;
3.4mm router cutter cuts the (pocket) groove for the 4.5mm thick MDF Bottom.
5mm roundover bit for the roundover handle grip - fluting toolpath with lead in and lead out.
Vee Cutter for vCarving the name - personalise this for each student
5mm router cutter cuts the pockets & profiles for the Handholes. housings, mortices, CutOuts.
We put tabs on all the pieces and although we have a vacuum bed we still use masking tape around the edges to stop the board moving.
Anyway it is there for you if you want it.
Yours sincerely and in good faith
Martin Reid
PS if you are interested you could email me and I'll send you the complete CRV file with all the toolpathing included.
