3 Attachment(s)
Mitering advice needed.....
Ok it's been at least 20 years since i had to do this last and frankly i have forgotten how to compensate for the differences so i need your advice.
I am putting up trim along the base of the staircase along a sheetrock wall with a 3.5" wide baseboard with a trim cap on top. (i'm using flat wood, what you see is scrap used to get my angles correct.)
It is a 40 degree angle where the two meet but by butting them up together you see the height difference? My vague recollection was somehow you split the difference and cut both at an angle and the joint is not a 90 degree straight up and down joint. how do i do this?
