Screaming bits revisited...
I saw the cheap bit post and thought I'd share. You do get what you pay for...
I purchased three 1/4" 2 flute compression bits early last October for the MakerFaire demo. When I tried to use them everyone looked around because the bits were screaming like a banshee. Fortunately I had a rather worn major mfg bit that did the job.
I'd forgotten about the 3 bits until a few weeks ago when I decided to give them a try again. All 3 were screamers. I took one of them and varied the chip load dramatically. Never got a quiet cut. When I went to change the bit immediatley after a cut... it was HOT. I checked, 160 degrees hot. I also noticed the cut edges were burnished looking in appearance.
What was going on? I tried one of the other three repeating the chipload range... the temp was always well above 100 degrees. I reloaded my pricey cutter and gave it a shot... never over 90 degrees even with the small chipload.
I can only speculate the problem was the geometry. Something about it was causing rubbing on the wood. Like using a bit designed for plastic for wood etc...
I tossed the 3 bits ($60+ ouch). Thinking about it... it wasn't worth it to save a few bucks. The other compression cutter may be 2 or 3 times the price but they work well and last 2 to 3 times longer... at least in my experience.
/RB
