I Want To Share This With You!
Hello,
My name is Mark John. Some of you may know me as a long time ShopBotter, while others may not have heard of me as I am not a regular poster here on the forum. I have been using ShopBot's for years to produce entry doors and various casework and millwork. You can check out my site at: http://www.distinctivedoorsofdallas.com for a sampling of what I do.
Anyhow, I just recently had a demo of the most amazing modification to a ShopBot I have ever experienced (it was a PRT model). There is a company in Dallas called Custom CNC Inc. (http://www.custom-cnc.com) that is producing replacement controller boxes for both the PR and PRT models. The performance difference that this new control box offers is nothing short of PHENOMENAL! You know how when you make a move or jog with the original box hooked up - and it is jerky and the motors growl and make all kinds of vibrations? Absolutely all of that is gone with this new box! In fact you can't even hear the motors run at all when you move or jog it around, and there are virtually no vibrations what so ever. And the cuts that were produced were equally impressive. I should add too that this new box made the system both faster and it was much more responsive (it didn't seem sluggish like what I am used to).
I've been a long-time ShopBotter and own both a PRT and a PRT-Alpha. The smooth cuts that I saw this old PRT do completely blow both of my systems right out of the water! This new box did not have the cut speeds that my Alpha has BUT it's not just cut speeds that I have to consider in my line of work - I also have to figure in the sanding/cleanup times too. I mainly do 3D work on entry doors, so I took a file with me for the demo to see just how much this new box would help me. All I can say is wow, no more sanding. The relief that was cut required almost no sanding at all!!! And the file executed 20-25% faster than on my PRT. I used to base my jobs on both cut time AND sanding time. Not any more - it's virtually just cut time only from here on out (I already have a box on order with these folks).
Also, the case isn't some 'hacked-up' PC case either. It has been made specifically for this application. The original motor cables plug right into the back so no wiring modifications are needed. These folks also put the other wiring connectors right on the back of the box for the ZZero plate and remote pause switch. They were also using a different software package called 'MACH'. In the brief time I saw it, it looked very easy to use, and has quite a few more capabilities than my ShopBot software does. It runs ".cnc" files instead of ".sbp" files, but once I saw how to make the ".cnc gcode files" it looks pretty simple too.
I just wanted to share this info with my fellow 'Botters. Thank you and have a wonderful day!
MJ
PS. The people at Custom-CNC have never had the Mach software crash in over 18 months of using it.
