Been doing plastic signs lately and got a deal on some 1/2" extruded for the punch through letters.
First time I did extruded and sure had issues at first. I used single flute O flute and cut at 8k RPM and 1"/sec. No extra cooling. The bit was an up cut 3/16D (Onsrud). For cast cut with same bit but faster on RPM and speed. Up-cut fights holddown but gets more plastic out of the way.
Richard wrote:
"I was going to mention as well there are different types of plastic. "
Richard, what is the brand of some carve able plastic you know?
Bill's problem reminds me of issue I had turning UHMW in a large manual lathe.
We were making rollers for the phone company and these chips wanted to reach out and touch somebody.
I once had a chip reach out into a previous pile, suddenly snag and I had a ball of UHMW as big as a four or six yard dumpster attacking the lathe chuck.
We later sent some UHMW to a cnc shop and discovered the CNC machine had a "peck" feature. The machine would cut and stop and the air blast kept the cutting area free. Only tiny little chips were produced.
@ Bill,
You said the plastic machines like chewing gum?
What about using dry ice to give the plastic some chill?
I am not sure. I have seen extensive spec sheets from GE Plastics though. I bet a search would yield something, or talk to your plastic suppliers about what works.
RIB
As they say "spilt milk under the bridge" er sumfin' like that... the job is done, delivered and a happy customer.
For now, in belief that it was a bad batch of acrylic with consistancy at fault (fingers crossed). The next time will bid higher on this brand of material just in case. I am going to set up for cooling air as well. Want to thank all for your help! Vortex (tooling) suggested the straight, 2 flute O flute to try and prevent the wrapping issue. Have off-cuts to experiment with once the straight O flute tooling gets here and will let all know what becomes of it all.
Once again, Thanks to all.
I cut some extruded, although it was 1/8", but used a 1/4" O-flute, single flute. Cut very nice and left a decent edge as well.
... just give an initial close watch if the material is brand named Evonik Ind. by Cyro Ind. That's the only extruded material brand I have had problems with.
Bill
could yu share source /techniques for the led strips that you use?
thanks
Carl
Is it possible to do some of the perimeter cutting on a table saw>
what bits are you using to engrave the clear acrylic?
