Anyone know where I can get the vacuum filter can itself??
Tim
Tim
I got mine from Wynn https://wynnenv.com/woodworking-filters/ Good people to deal with. I called and they helped me select the right filter for my unit.
I strongly second that recommendation from Phil.
Jeff
Sorry, I wasn't very clear , looking for the can that holds a filter like the home depot shop vac but for my vacuum hold down setup
Maybe a picture Tim?
Is your vac grid open to your shop or do you glue your spoiler board to it?
If your spoiler board is glued to it I see no reason to add a filter. Nothing but air is getting through that mdf.
Yes Scott I think a picture would be lots better
I have a filter at the opening of my not black box now but have no easy way to take it out and clean it so I would like to find the housing for a removable filter.
I thought at one time I read where the Home Depot brand shop vac filter fits in one of these housings.
Tim
This is my solution for the problem. It was made from scrap that I had on hand so I can't really put a price on it. The plexi is 1/2 inch thick. Gasket came from All Star Adhesives. To fasten in the plastic plumbing ends I used some gas tank sealer that I had on hand. It is a two part epoxy product that really sticks well. I am sure most any caulk would do this job. After I finished I schmeared a little silicon sealer on the edges while it was under vacuum to help seal. It works great with no leaks at all that I can detect. The filter itself is a $10 unit from Ace Hardware that was sold as a filter for your shopvac.
http://www.talkshopbot.com/forum/att...id=29211&stc=1http://www.talkshopbot.com/forum/att...id=29212&stc=1http://www.talkshopbot.com/forum/att...id=29213&stc=1
Super cheap. Very easy. (Though Tom's is much sexier!)
Old gallon bucket of plastic resin glue. PVC fittings screwed in place, sealed with silicone. Filter was about 10 bucks.
I like the black bullet end- any debris hits it vs paper in event of a disaster. Glued a couple scraps on inside edge of bucket to help seat the orange gasket base against lid for a proper seal. Lid is a snap lock and seals perfectly. Fits in line just outside my 4 motor black box, which has been running trouble free close to 5 years now.
Jeff
Attachment 29217Attachment 29218
