Desktop x proximity switch adjustment
The x proximity works, if you push it when the x axis is moving it stops. But when it is mounted on the rail, the bar that is suppose to trigger it passes right over it. I moved it to the right from the factory mounting position and the bar passed over the switch and dislodged the switch plug. Are there adjustment screws for the bar to move it closer to the rail to trigger the switch. This is a very old 24x18 desktop that belongs to a friend.(maybe 8 years old?) The y proximity switch does work. Thank for any help.
