Need help with an Aspire 3D issued
I have aspire and a great scan of a 3D object I want to cut out when I run a preview everything is fine on the object.
But because of my fixturing I have to turn the object around a hundred eighty degrees to where it's pointed in the opposite direction and also move it down on the table a few clicks when I turn it around and try to preview a roughing tool path and a finish tool path it does not cut out correctly anymore and this carries over to the actual cutting any idea why?
Also I am cutting Hardwoods such as mahogany Maple and I think I was running three or four hundred inches per minute but I was only taking off .050 per pass and the last couple of tries and seems as though my X&Y has gotten off a little each time not for sure what's causing that any ideas would be appreciated on both topics
I
