Loss of Y then Y&Z
Ok this will be a hard one to explain.
Here is the scaled down attempt
Was cutting a large 3d file (about 5hrs) with .0321 ball nose bit, speeds 5,3...
1) Lost Y position intermittently (see photo below)
2) Checked file and Y positions were fine
3) Called SB support
4) Switched Y and Z red,white, green, black wires in control panel and switched values input driver definition for Y and Z--no luck
5) Switched Y and Z motors and all ran fine with no problems
7) Next day went to cut a simple square pocket lost location on both Y and Z axis--Z off about 3/16" and Y off by about 1.5", X was fine
8) Tried different laptop
Tried SB support this morning and they have not gotten back to me yet.
Tried a different computer--no luck
Help. Christmas business is suffering. Any other possibilities or suggestions?
Angelo
Attachment 32292
An intermittent loss like that can be due to a grounding issue. If your tool is grounded check all the connections and make sure they haven't come loose. If it isn't, then you need to do so.
A "grounding" search will lead to plenty of info in how.
Please try the following:
1) Run VR command. At bottom of fill-in sheet, click on Reset.
2) Slow things down to 2,1 and see if it still loses steps/position.
What machine are you running? (Desktop, Buddy, Gantry tool - assuming this is not an Alpha)
Just noticed-the original post was from December 2018.
Hopefully he got it solved.
