how is everyone storing all you router bits, spanners, collets, hold down bolts etc, all the extra stuff that goes with the machine
I have a cabinet that the pc is in and has drawers for all that stuff.
how is everyone organising all that stuff
I built a cabinet that mounts under the end of the router which houses the PC and control box. I, too, have a shelf inside which I have compartmentalized tray to hold the router bits and other essentials.
I took the easy way out for bits, i bought two of these and screwed them to the wall right above my table. Works for me.
http://www.rockler.com/18-rockler-ro...t-storage-rack
I have a drawer cabinet for the accessories and a kind of Rolodex storage for the bits. Although, I should have made it bigger it is already full..
https://lh3.googleusercontent.com/qM...=w1544-h949-no
The dividers are captive with dowels but they can flip back and forth to make each row more accessible. The bits usually don't touch except the real big ones like 1 or 1.5" diameter. There are frontal slots at the bottom of the holes for the bits so that dust or chips can fall out and don't clog the hole.
Took scrap 2x4's and drilled 1/4", 3/8" and 1/2" holes and stuck the bits in. For collets, I inserted a 1/4" dowel in some of the 1/4" holes and that's where they sit. Same for collet nuts. The 2x4's sit in my cabinet that has my computer. I chose the cheap-scape route :)
Another quick & dirty approach. Just took a piece of scrap plywood and cut holes and pockets with the ShopBot. Pockets are for storing backup end mills. Sometimes I peel the labels off the Onsrud cases and stick to the plywood. Sits in a Vidmar cabinet drawer.
Attachment 30746
how is everyone storing ll the other stuff that's needed. bits a fairly straight forward to organise
Dear All
Here’s my two penn'orth.
Attachment 30777
(Click to enlarge - Tool Shelf)
Have a organiser shelf on the 'zero' edge of the bench for the day to day tooling (collets, spanners, chuck-key etc) and 'in-use' cutters for the project in hand - ready for the manual tool changing.
As most others the 'cutter store' is in the office with the computer so they can be cross referenced with the tool database.
In good faith
Martin
