2 Attachment(s)
V-carve - ridges left after cut
Hi,
Just curious if anybody has seen small little ridges left after a v-carve cut. The ridges seem to show between the toolpath operation of going up to create a sharp corner in the V-Carve and between doing a straight line or curve.
I checked Z-Zero repeatability and it seems to change by .005-.010" after the cut is done. The Z actually goes downward which I found weird. Though it might adjust up a bit due to upward pressure when cutting. I reduced the cut depth to .1875 assuming it might be deflection. I am using a new collet and 1/2" 120deg v bit but this shows up with 90 degree bits as well.
The gears in the XYZ appear to be fairly tight. There is a little click sound but very small movement.
Any thoughts on things to try and check would be great!
Cory
Attachment 33856Attachment 33857
