I recently undated my prs std to 3.8.50 Even prior my V1000 would not change speeds during warmup nor as tool specs dictated...any assist appreciated.
Check to be sure you have configured the RPM controller to use the V1000. The default is something else. You can reach the RPM controller by clicking on the word "RPM" in the RPM window. There are a couple of parameters you have to adjust, the kind of VFD and one other, I think it's called frequency. The default is 100. The V1000 uses 60. Caution: I use the 3.6 software so 3.8 may be different.
Thank you. All parameters check out. VFD V1000=60. Start when SB3 starts: 1
Issue still stands.
Contact SB support.
