anyone interested in this?
if you have a prt or older it is a hassle squaring the z.
I am making is a simple upside down t that screws to the z uses two bolts in each end as leveling screws. one on each size of the z.
Several people have made these and I made one out of aluminum that has to much flex but hey it was easy. The video below shows mine a bit (forgot to take a picture of course taxes dulled my brain) I am having these part cut at my local waterjet place. the two bottom pieces are welded together to make a angle iron piece so it will not flex the two holes with be threaded for the bolts. then the top piece is welded and the small piece connects the horizontal to vertical. You just have to drill and twp two holes in the z on each side. it is cut from 1/8" steel I was going to do 1/4" but that seemed overkill and doubled the cost of getting it cut.
http://i154.photobucket.com/albums/s...ing/zbrace.jpg
http://i154.photobucket.com/albums/s...g/IMG_1405.jpg
http://i154.photobucket.com/albums/s...h_9b5dcb22.jpg
