Those look to be M5 set screws -- 0.96" is a little under 2.5mm -- and a 2.5mm allen key should fit an M5 -- snapping a measurement from the photo you posted seems to agree. I'm not sure why the set screws would have changed from 1/4-20 to M5 -- Although -- I looked up your order from 2017 to get the part number. There is a note on that part that suggests that back in 2012 we had 1/2 pinions bored out to 14mm by our supplier to fit the motors we were using. Since then, it looks like we are purchasing a pinion that comes standard with 14mm bore -- which would likely mean metric set screws. M5 is a fine-thread screw and should be able to take about 5 ftlb of torque vs about 9ftlb for a 1/4-20.
Thank you Brian for looking into this. Maybe this sound dumb,,,,,,, while I am no machinist, I do have a couple of complete sets of English and metric Allen wrenches, plus a box full of misc. I didn't find any that fit right........ I found loose fits, and just a bit too big fits..... Where as I have a bunch of 1/8" Allen wrenches. Doesn't an M5 set screw boarder on a specialty size?
I came very close to trying to just tighten these set screws with what I had, as it was late at night and I wasn't thinking well. But then I realized I'd be the one stuck trying to deal with loose set screws. I will drill mine out and end up with a bigger/common sized hole in my pinions.
Thanks, Chuck
Chuck,
The M5 x 0.8 is pretty typical in metric stuff -- it is also just about a perfect match to a 10-32 (good thing to remember when you're in a pinch and don't have any metric screws!) -- the socket cap M5 uses a 3mm (almost 1/8") allen -- but the set screw variety uses the 2.5mm (same as the socket cap M4) Most metric allen sets should have a 2.5 so it could be worth another try (maybe some crud on the screw blocking the socket?). Though as others have said--you should have no problem drilling out and re-tapping and M5 hole to 1/4-20 and getting full threads.
Brian
Fine thread
A "Fine thread tap" is much easier to use for tapping such a shallow hole...
I think I have thrown my 1/4 20 away....
3 Attachment(s)
Well, as was suggested, it turned out the drilling and tapping of the 4 pinions was not hard. I think I spent a total of 2 hours to do these. But it took 7 days before I started............... I mounted the tap into my drill press chuck, and turned it by hand as Brady suggested. Thanks everyone for your input! Chuckhttp://www.talkshopbot.com/forum/att...id=32807&stc=1http://www.talkshopbot.com/forum/att...id=32808&stc=1http://www.talkshopbot.com/forum/att...id=32809&stc=1
I never thought of doing that. Missed where Brady recommended that. Great idea. I will keep that in the back of my brain for reference.
