Can't import a particular jpeg into aspire 8.5 for bitmap tracing
Hello Aspire experts... I created a JPEG in Photoshop, and then imported it into Aspire, 8.5. I brought it in to a new Aspire file, for the purposes of making a 2 1/2D relief image, but I only get an error message which says: "Failed to load image. Check if image is supported type." I can't figure out what is wrong, even though I have done this same type of operation many times without any problems.
Here are some details:
It is a simple line drawing in black and white, (it is not a vector image). I did use the little birdie "import bit map for tracing" icon.
A few hours ago, the first time I imported this JPEG into Aspire, it worked fine, BUT, the image was far too small, (upon expanding it in Aspire, the JPEG became pixelated).
So I went back to Photoshop, and resized my original image so that it would come into Aspire at the right size for the workspace. And I then created a new JPEG of the resized image. From that point on, every time I tried to import the revised JPEG, I got the error message: "Failed to load image. Check if image is supported type."
I have checked and rechecked that I created a JPEG, and I did. The JPEG is 3.5M, and I found other JPEGs of similar and larger sizes which I imported into Aspire without problems. I checked to see if there were any patches available for Aspire, and there was one, which I installed shortly before coming onto the forum. I have made new copies of the JPEG, but to no avail. I have shut down Aspire and restarted it,,,, but I can NOT open this file in Aspire.
Because the image file is 3.5MB, I can't attach it to this post. I'll see if I have some sort of zip application, and will attach with that later.
What do I do????? Thank you, Chuck
