I am sure all you guys that built one from his design sent him a donation for his R & D. Right? 30 bucks is a lot cheaper than the ones you can buy that only work marginally as well. At least send him what you saved in shipping cost.
For those using a cyclone lid with a shop vac you must drill a 3/4" "bleed" hole near the inlet to the lid to prevent a complete vacuum from occuring and collapsing the can. This is outlined in the LEE VALLEY instruction sheet it is not required with dust collectors only with shop vacuums.
I use my cyclone lid currently on a very stiff barrel and don't have the bleed hole but originally I tested on a plastic Rubbermaid garbage pail which it collapsed regularly. If you plug the hose and don't have a bleed hole you can actually "invert" the lid into the can as well! It occurs with a very startling bang :-) Scared the beejeezis out of me first time it happened!
gerald
Although on the higher end of price scale, this should be considered to convert your double bagger - my review and photo at this site explains:
http://www.amazon.com/Cyclone-CYCLON...6085903&sr=8-4
investing on the cardboard cans is worthwhile the lids seal better and they don't collapse. here is another way to go.
http://www.oneida-air.com/inventoryD.asp?item_no=AXD000010&CatId={428A1AFA-E859-459E-8BF9-47817428D9AF}
I've had the colapsing garbage cans as well . --I recently bought one of these : http://www.busybeetools.com/products...NE-ONEIDA.html --and it is far superior to the cyclone lid . -I have have on my bandsaw and no dust makes it to the vacuum now . I used to have to unplug the pleated filter on the shopvac once a day before I installed this .
I have the "Ultimate Dust Deputy" for my Festool dust extractor. Wowsers! That Oneida unit REALLY does the trick.
I bought a General bucket & lid thing I tried first with my shop vac but it let a lot of dust through to the filter bag. The Oneida unit stops almost all fine dust before it gets to the vac.
I also have the 2nd largest Oneida cyclone hooked up to my central dust collector (a Belfab 7.5hp unit). It also made a HUGE difference in the performance. I am sold on the Oneida products.
Busy Bee also sells the exact same unit as the General one, with a blue lid instead of orange - for the $40 it costs I wouldnt waste my $$. The $100 you will spend on the Oneida unit will be worth it.
AJC
I use these - http://www.axminster.co.uk/axminster...ood-prod21891/
Cheap and work perfectly. No dust at all in the chips and shavings.
Here is another source for dust deputy in Canada. Great place to buy from. Free shipping in Canada for over $50....what tool store do we spend less than $50 in...:D
http://www.elitetools.ca/en/product/...deputy-deluxe/
For those willing to build their own, I have photos of a DIY cyclone built entirely from recycled materials for use with a ShopVac at http://www.iedu.com/ww/MiniCyclone
At the same time that I ordered my PRT, I bought a bag-type dust collector from Harbor Freight and two lids from Lee Valley. I used two 55-gallon barrels to capture the dust, and ten years later the bags were still empty. You can see a small photo of that lash-up at http://www.iedu.com/ww (right below the photo of the ShopVac mini-cyclone).
Enjoy! :)
