Anyone with an indexer want to do a run of 100-400 pieces?
Is there someone with a 4th axis who is interested in doing a run of 100-400 pieces? I’ve been doing the proof-of-concepts, but I don’t have the time to do production runs.
The item would be carved from basswood, 4 inch diameter, about 8" in length.
Machine time would be about 40 minutes per piece (I’m still fine-tuning the toolpaths) and should be able to be cut entirely with a 1/2" ball nose. (Rough, waterline, finish).
Due to the geometry the item cannot be toolpathed with any of the Vectric products. I’ve been using DeskProto for machining the proof-of-concept. It is still 3-axis machining. This could probably also be done in more advanced CAM packages such as MasterCAM.
The customer is located in southern California.
Let me know and I put you in contact with the customer.
Randall Newcomb
randall@222artisans.com
