Change in speed value (VS) need defaults back
While in move/jog mode a pop up window appeared stating something had changed. I kind of ignored it since I didn't change anything. Then as I went to move in XY I appeared to not want to move although the coordinates were changing slightly. After cutting power to the control box and rebooting, same problem. I started over trying to move the gantry in move mode, still nothing. After closer inspection the gantry was moving, just very slowly. Z always moved correctly. After trying to remember what the pop up window said, I went into the values and see what I could find. I found the XY move speed is 0.05. This does not seem correct. Does anyone or have values that I can change these back to, or a default setting. Attached is a screen shot of the current values.http://www.talkshopbot.com/forum/att...id=34204&stc=1
