Poor Surface at LOW Chipload as well as Perhaps Deflection?
Hey guys, I did some searching and couldn't seem to find answers here. My two current issues seem to be:
1- Lower-than-expected surface quality at less than half bit's recommended chipload
2- Poor match-up when milling shapes; half thickness done from the front, flipped, and then the other half of the thickness milled from the back.
Problem 1 details:
Awhile back when first learning feeds and speeds I did the recommended tests with my machine, desired bits, and usual materials. Using a 1/4" single-flute Onsrud upcut O bit (if I read correctly that's a recommendation of .005-.007 chipload in hardwood) I ran channels at various chiploads across hardwood end grain to determine what chipload I should actually use. I found that my best surfaces were .002 and below! The difference between .002 and lower was minimal, so I've been running things at .002. However, even at feeds/speeds using this chipload I'm still finding lower-than-expected surface quality, especially on end grain!
Basically I'm running at .002 (24IPM/12,000RPM x 1 flute) and running .2" DOC climb as a profile cut offset .015" til I reach about 7/8" depth. I then come back and do an onionskin pass full depth to remove that last .015" as conventional. On end grain sections of these profiles I'm still finding that my surface requires significant RO sanding with 120 grit to get out all of the surface blemishes. The blemishes generally look like chipout on the end grain, or perhaps it could be grain tearing and compressing? Either way, it's not up to snuff! It's do-able... but I'm getting tired of the extra work!
In areas of pure end-grain it happens everywhere. However, in areas where there are curves slowly transitioning from end grain to face grain it's often only on half the thickness. What I mean by this is in places where the milling that was done from the top has the blemishes, the milling from the back won't, and vice versa.
Note: I do the onion skin as the surface left from the initial passes is even worse. I attributed this to the bit being deep in a confined channel, often with debris despite upcut bits. Hence doing the onionskin at least gives the bit .015" breathing room on the final pass.
Problem 2 details:
As mentioned above I'm milling half my thickness (total 1.75") from the front, flipping things over, and milling the other half from the back. I have index pins (1/4") that allow me to accurately register the piece when flipping it. Again, bulk of the work is done with profile climb cuts and then the onionskin pass as conventional to get an 'as good as I seem to be able to get so far' surface. However, where these two passes meet in the center of the thickness they never seem to be perfectly lined up! I just measured and the current piece I haven't sanded yet, this is a .005" difference. But it's been bigger. Would estimate up to .010"?
My first inclination was that the bits weren't square to the table... but a quick check with a long bit and a good square makes me not think this anymore.
I then thought back to when I read somewhere that bits will deflect due to rotational forces... and that they'll deflect in vs. out depending on climb vs. conventional cutting? Could this be the cause of what I'm seeing? If so, is my only choice here to bump up to larger diameter (lower deflection) bits for this work?
Thoughts?
Chris
