Automatic G-Code Generation – Dovetails, Mortise and Tenon, Dados, Rabbets and More
These cuts are the foundation for furniture and cabinet building and now they can be created in just a few minutes using Cambium Code Standard. A complete g-code program can be generated very quickly by simply entering parameters for stock size, cut size and placement, feed rates, etc.
This approach is backwards from the standard process of designing in a CAD package, exporting to a CAM package, then generating a g-code file. Our method will save you considerable time, since you need only enter a handful of parameters and some standard text.
With Scripts to Generate Part Models in SketchUp
In addition to generating G-code, plugins are available for Google SketchUp which will automatically generate the part in SketchUp.
The program – CambumCode Standard – is available for download at
http://www.cambiummachines.com/CambiumCodeStandard.html
Thanks for checking us out.
