Precise bits no longer supports the 890 series and I could really use a 1/8 th collet are there any options out there. I'm a little hesitant to use adapter sleeves. Thanks
Use a stubby collet chuck.
I bought one from Elaire Corp
http://www.elairecorp.com/portercabl...FeJF7Aod4wQAkQ
I have had no problem with these
http://www.mlcswoodworking.com/shops...ollet+adapters
I use a bit of Locktite blue on the 1/8 inch bits.
The collets from PB work fine on that router, call up or email the guy.
I saw what is written on his site, more of a caveat than anything.
The issue is that the chuck appears to have changed on newer 890 routers. They don't have enough threads to get more than about a half turn on the nut. If you have an older one it shouldn't be an issue.
For obvious reasons I will not comment on the other products mentioned as I am biased. Just wanted to clear up any confusion.
Please let me know if there is anything I can help with.
