Aspire Wrapping Issue
http://www.talkshopbot.com/forum/att...id=31111&stc=1
Any advice on what I'm doing wrong here would be appreciated. My indexer runs along the x axis on my machine and I do not see any x movement on either of these part files.
When I wrap it along the y axis, you can see that it still has the y moving instead of the x axis and it is only moving the length of the flattened blank instead of the length of it like when it is wrapped on the x axis.
Changing which axis was wrapped was the only setting change I made in Aspire on the two part files in the photo...
2 Attachment(s)
Attachment 31112Attachment 31113
Here are the .sbp files with the wrappings on different axis.
Are you changing post processors?
There are separate processors for wrapping X along Y, and wrapping Y along X.
Oops, my bad. I was thinking of the Shark post processors.
You were actually spot on. While Aspire does have an indexer post processor for Shopbot, I had to go find the two separate ones inside the Shopbot folders and add them to Aspire. It's now finally cutting away. Thank you for the reply!
