Is there still a 999,999 line limitation on .sbp program length?
-or-
What is the maximum number of lines allowed in .sbp program?
-or-
Current version, 3.8.42 is 10,000,000. Not sure what version it was, but it was lower and I did run into it on a large 3D file once several years ago.
You can check it under utilities and depending on the version it will be some sub heading under there.
I run into a error with too many parts in aspire. if there were a couple hundred I could not select them all or I would get a error. wonder if the new version has that limitation?
