There's certainly no issue cutting AL on the Bot - thin sheet or thicker parts up to let's say 1.5" thick - that are held down well, can produce good results.
If you need to do production in thick AL or steel that requires lube & coolant - then farming it out or investing in a CNC mill like a Tormach is a wise decision...although I have to say, farming it out is no fun for guys who like tinkering or the occasional Saturday metal project.
With the Colombo, I use a spiral-O bit up to about 1/2" thick. If doing extensive area clears/pocketing, I will use a HSS end mill with a geometry suitable for milling AL. The HSS absorbs some of the harmonic vibration that you can get when milling AL with solid carbide end mills in certain diameters & feeds. Plus HSS will bend in situations where carbide will snap or shatter.
You can mill 2D and 3D in most non-ferrous metals with your router. As Jeff pointed out, you can't walk away when milling this stuff & you can't be asleep at the wheel while programming or operating.
We've been using Amana Tool's polishing flute aluminum cutters, and they work great.
We do roughing passes down to an onion skin 0.005 offset, then a cleanup pass with no offset and full depth. We run 1.5 IPS with .14" passes at 18,000 RPM with a 2.2 HP spindle.
Tabs hold like crazy in aluminum, so you don't need very many to keep the part in place while cutting this way.
