What keeps you from using your indexer/rotary/4th axis?
I have a similar thread on the Vectric forum, but I wanted to post here in just to get better coverage.
I'm putting together some training material on wrapped rotary machining. I'd like to hear from those of you who are curious about rotary axis, but haven't really done anything with it.
If you do have one, have you done anything with it yet? (Mine sat under the CNC table for 2-3 years before I did anything with it)
If not, why?
If yes, what problems did you encounter?
For those with an unused rotary...
Do you have to swap a controller and/or a motor in order to use it?
Does it sit in/on the bed of the table or off to the side? i.e. do you have to set up/tear down something to use it, or can you quickly switch between table work and rotary work?
Have you ever hooked it up, and can you turn it with the control software?
What are the very basic questions you wish someone would address regarding rotary?
