Guys, I am looking for a UV curable topcoat that will block sunlight UV aging effects.
Google isnt helping.
I need an actual UV curable finish
with a UV machine
go to mas epoxy they will help you.
Not exactly sure WHY you need the UV curing property, could you elaborate a bit? In the meantime this stuff works very well for almost everything- http://www.permalac.com/
Here's one that is waterborne and made for exterior use:
http://www.azom.com/news.aspx?newsID=2737
Try a search for UV cured urethane and/or UV cured polyurethane.
AH, When the only tool you have is a hammer, everything looks like a ....
