I have a prt 48x96 I upgraded to a 4g control box . my problem is in aspire my x and y axis are different. is there a way I can switch the control box to change x and y direction
You should change x-0 and y-0 in Aspire or...
Your origin should not have changed due to the upgraded box but assuming you changed the overall settings in SB-3 by running set-up (and/or upgraded your SB-3 you might need to go back in to set-up and make sure the entries there are correct.
Can you draw a quick sketch of how the axes are oriented now and what you would like to change them to?
Both Aspire and SB control software Origin location are simply making the correct settings in the software. Call Shopbot direct and they will get you going the right way quickly.
I had to go to values and change x input and y input very easy but it sure took me a long time to find the trouble thanks for your help
