Setting up hard stops and prox on Buddy
I recently purchased a used/never ran 24” Shopboy Buddy from a government auction. I have it setup with power on it and was looking at zeroing the x-y-z axis’ and have a question before I do. I see the hard stops on the Y-axis fastened to the extrusion but they are loose and not in the proper position. Is there a dimension drawing or something as to where they should go. I can’t tell for sure but it looks like the part of the moving carriage that contacts the hard stop is the pinion gear, is that correct or is there something missing? Ramming the gear into a hard stop does not seem right, even if it seldom happens. I guess I then set the prox switch actuators at a position just before the hard stops hit.....Thanks, Mike
