Comm errors have been an ongoing, since new (3 months), problem with my PRS Alpha and 4 hp single phase spindle. Grounding has solved 'some' of the errors but until yesterday I could not do a continuous cut for more than 15-20 minutes without an error. Prior to my grounding exercise (x-rails tied together, x-rail to dust collector, wire through dust collector hose, x-rail to ground inside control box and x-rail to pc chassis, I often could not get past a few minutes without an error. So what happened yesterday? I decided to ground the spindle control box chassis even though it was grounded via the power cable from the control box. When I opened the spindle control box (first time ever) to see where it was safe to drill a hole for a ground screw I found the little board which the USB plugs into resting on top of the fans inside the control box. The four little foam stickies had let loose at some time. I relocated the board and grounded the control box chassis to the control box heat sink and to the x-rail.
So, since that time I've cut two test files, each over two hours long AND the spindle speed control on the pc now works (it never did!).
No happy dance yet, but I'm warming up......
