I need to carve a circular pattern for a foundry. The pattern is 15.5" in diameter and has a z of about .5". The foundry will make a wax casting from it, do some hand detailing, and then make a rubber mold. Here's the question: What material should I use to cut the pattern? It needs to be about .75" thick and at least 16" wide. Any suggestions would be appreciated!
