Has anyone run across this problem. In a job i just machined two upper cabinets sides had their holes drilled in the wrong spot. One side was offset from the other by about 5mm. I checked the cabinets in the Lde and they all checked out. These cabinet all came from the same seed cabinet. Also I tried previously to equalize my shelf holes in the shelf editer so I wouldn't have to check for left or right sides. For some reason that didn't work.They turned out to be about 5mm offset than what they showed in the Lde. Any ideas?
Mike
