I have some one who needs a molding around the window in mdf as I was quick to say maybe. Hho complicated is this TO DO AS I'VE NEVER DONE ONE I think its a great oppertuinty to learn something new
Kevin,
MDF molding around this window would be fairly easy using Aspire. Get the radius or make a template then put it into Aspire and use a two rail sweep to create the profile you need then let your Shopbot go to work for you.
I'm getting ready to build 2 large vertical grain douglas fir doors, side lights and transom lights for a hotel in Canada. The transom windows are curved. With the Shopbot I can cut the exact profile and then use my door making bits to route the profile on the router table.
Don
www.dlwoodworks.com
Use PVC boards instead of MDF. More expensive but will last longer and just as easy to mill.
Look in the threads. You will find a link to calculating the radius with the width and height measurements. That is what I do. Then add the reveal to the radius and cut it. I run the profile in the moulder but if you have Aspire or some other 3D software I am sure you can easily enough cut the profile before cutting out the arch.
Good luckh
ttp://www.talkshopbot.com/forum/showthread.php?t=5214
Lorin
Thanks for the help
Its funny what you forget I use to use these calcuation in oval furniture
I made a second one smaller as a sample in the new showroom
forgot pictures
Did you cut the profile on the Bot?
That second one I really like. That is something to think about. All I have done is match other mouldings in the house.
Lorin
yes on the bot
the second one is 3d clipart
