of course I can't find the name of it but it is a roundover with a point. the flat tipped ones can't get into the tight area's of letters. I can find smaller ones but I need one with a 1/4 r 1/2" diameter curve. the largest one I have found is 3/8"
Harold
Let me DROP EVERYTHING and work on YOUR job!!
Steve, I have used bits like what you describe. Although not that brand given in a reply, I was somewhat disappointed in the results. These type of bits have a tendency to scrape or rip the wood fiber at the very point of the cutter. The bits are not possible to be made with a cutting edge in the fine point area. Their cut makes it necessary to sand in the point area.
not my favorite brand but that will work. I am only cutting mdf so that won't be an issue. plus I offset it a couple hundredths. so when I use a straight bit to cut it out any of that will be cut away.
Steve try this:http://www.ballewsawandtool.com/shop...rm-tool-2.html
Steve this is great company to work with have always been able to get any thing I needed
