I haven't used my probing program in quite awhile and just ran a 3.5 mb file with version 3.6.14. The probing results are excellent, however, when I run the program at MS 2.5,2.5 the SB seems to run around MS .5 regarless of was MS is assigned. The movement is very jerky in X, the major axis. It does smooth out with higher ramp settings but MS is slow. Comm speed 74% which is good. As you can see in the program code the probe was set to sample every .05" and took around 6 hrs. to complete. The probe was tape covered wood part to metal .5" stylus..normal for all our probed parts.
Called SB and so far all seems to run perfect on Frank's simulator. Another wierd effect when running preview on VisEdit is some of the file does not project the part properely, some area's missing and others having unusual Z & Y moves but on SB previewer the file looks great.
Any ideas or suggestions? I feel it has to do with a ramping issue but tried resetting factory setting, rebooting, adjusting ramps, thresholds and any other setting in VR that looked appropiate.
