Jack,
Yes I have/use a DC while machining.
All cables are behind the SB out of my work area.
Consider this current situation:
1) I am carving seven plaques for a family member.
2) The first cutting file (rough machining with DC on) and is about 90 minutes long. The program seems to go about half way through then stops with a "Comm" message.
3) The second cutting file (finishing with DC on) is 6 hr 40 min long. It runs fine with no "Comm" errors.
The only thing different is that the rough machining process is using more cutting force on the spindle and stepper motors and the amount of dust is greater than on the finishing program.
I have copper wire running through the center of the hose and wrapped around the hose. The copper wires are connected to the DC frame and the SB electrical panel frame.
George Kelly
