View Poll Results: SB Link Users: How do you Zero Your Bits?
Voters
30. You may not vote on this poll
  • To the Top of Material with no Bit Changes
    5 16.67%
  • To the Spoilboard with no Bit Changes
    9 30.00%
  • Top of Material Before and After Toolchange
    10 33.33%
  • To Spoilboard Before Toolchange and Material After
    6 20.00%
  • Separate Zero Location
    4 13.33%
Multiple Choice Poll.
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: SB Link User Poll
    Apr 2007
    Marquette, MI
    Default SB Link User Poll
    Link Users: How do you Zero your Bits?
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Nov 2007
    , Royersford PA
    I do spoil before and material after...but intend to swap to Kenneths separate zero spot setup.
    Apr 2007
    Marquette, MI
    I now notice I didnt add the version I will use. To the spoilboard AND a separate zero block.
    You can select more than 1 answer
    Gary Campbell
    GCnC Control
    Albert Einstein
    Dec 2008
    , Richmond Tx
    Is this a trick question?
    Kenneth
    Apr 2007
    Marquette, MI
    Kenneth...
    Yes... I didnt ask if your zero block is at spoilboard or material level
    Gary Campbell
    GCnC Control
    Albert Einstein
    Dec 2008
    Diamond Lake, WA
    My current eCabs design strategy doesn't require me to change bits, but I would like more flexibility in this regard.
    I will be adopting Kenneth's version soon. My zero plate is already installed. Now I just have to modify my tool change files to zero at this location after a bit change.
    Don
    www.dlwoodworks.com
    Nov 2006
    Waterville, Maine
    I use the method that Bill Palumbo taught at the Camp ShopBot I first attended: whichever way is best suited to any given project.
    Jan 2006
    Un-Employed Westminster, Ca
    I am surprised to see so many options to do the same thing, zero your Z.
    Thermwood designed the system to zero to the bed.
    Works really well.
    Who is writing your tool changing routines to zero elsewhere?
    Is SHopBot sending out these files? Or are you guys doing the modifications?
    How do you get your joints to fit correctly by zeroing to the material?
    Apr 2007
    Marquette, MI
    Roger...
    Unless someone adds a separate zero location, (read as Cost, expertise, wiring and programming) which all users are not able to do, how would a 4 by 8 machine be zeroed after a toolchange if not to the top of the material? And if you are going to make subsequent zeros to the material top, why not the first one? As usual, the options and methods are as varied as the ShopBotters that are using the tools.
    All of us that zero to bed... always... know there is an accuracy advantage, but all dont have that option.
    I have just finished some testing on the new machine, and it looks like my answer is..... zeros are not needed. Since I zero to bed for all files, and the SB ATC files keep track of all bit heights to the zero plate and the plate to table surface, all I have to do is keep a surfacer in the rack and voila! no more zero plate. I rewrote my surfacer routine to update the plate offset to table... and I am stylin'!
    It took a little work to get the zshift implemented and havnt heard from SB for the final word, but looks very promising. Tomorrow I will be testing Vectric posts with the z shift added.
    Gary Campbell
    GCnC Control
    Albert Einstein
    Jan 2006
    I guess if you have to change bits in the middle of the file you are stuck zeroing to the material. I forgot about that. I don't have to change bits.
    The best way is a separate zero location. That is how Thermwood does it on there machines. A little work to get that up and working but I would think would be worth it.
  1. SB Link Training Video User Input
    By Gary Campbell in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 06-05-2022, 11:54 AM
  2. Wireless Keyboard Poll
    By Brady Watson in forum ShopBotter Message Board
    Last Post: 12-02-2011, 09:19 AM
  3. SB Link User Poll
    Last Post: 05-25-2011, 11:16 PM
  4. Last Poll, I Promise
    Last Post: 08-12-2010, 11:12 AM
  5. SB Link Cutting Tools Poll
    Last Post: 06-16-2010, 07:58 PM
