Hi everybody,
Yesterday afternoon I cut a part out of mdf on my prs standard. It was .75" MDF that was getting some small 3/8" diameter holes drilled thru the panel. On the top side there was also a 1" D counter bore 1/8" deep. The counter bore was for the heads of some t-nuts that are going into the panel. When I installed the t-nuts it became obvious that the holes were very sloppy. Not at all concentric. The good news was they were consistently out of round.
The tool paths were created in partworks and the bit was a 1/4" down spiral bit running at 2"/ sec. The cut was a climb cut.
Would someone have any suggestions on what to look for or change? The motors are all tight and the machine is cutting square.
Thanks for any advice,
Tim
