Dave, we know who the boob is...the guy asking the question...(ME!)
Greg when you explain it, it makes perfect sense. When i look at it I thought i could see 4 or 6 varying depths and the sails looked like they had wind behind them and not just a flat representation of a full sail.
It might be because of the light or shadow lines or because of the talent of the painter for sure. All in all a great job.
Curtis - Industrial Polymers makes Styrospray.
Blue foam came from blue themed home improvement store in 1/2" - 4x8 sheets. To be precise it was on isle 17, about 15 feet from the end cap, near the front of the store.
Jack - There ARE varying depths. I did the glue up first. It is 2- 4x8 sheets I thought you were asking if I cut it in slices and then assembled the slices. But the sails are definitely full of wind. I just painted what is raised in relief, after we sealed it with primer. It finishes smooth as glass and keep detail. Really cool product.
Here is the sign covered before I trimmed and painted it.
Blue (Lowes) or Pink (HomeDepot) goes under the name EPS (Extruded Polystryrene) insulation. Look in the insulation area of your lumberyard. The pink is Owens Corning F150 (the F stands for Foamular). Lowes doesn't carry it here (must be too warm for insulation...) but 2" x 4' x 8' pink goes for $29 and change.
I just painted a few pieces yesterday with the Styroprime (a thick primer they sell) and hope to try the 2 part StyroSpray later today. It comes out of Houston from a company called Industrial Polymers Inc. http://www.styrospray.com/ $110.10 for a gallon of part A and a gallon of part B (2 gallons total for that price).
Boy, you sure have to be quick around here this morning! By the time I finished my reply to the foam question there were already 4 of them!
Greg,
Did you lose detail with the primer? The stuff I have is really thick and some of my fine lines seemed to fill in...
Greg - Looks great! What brand and part # cutter did you use on the blue foam? Feeds and Speeds?
Thanks.
Michael - Didn't loose detail, use a foam brush to "squeeze out" the excess in the cracks and creases.
Brad - Onsrud 1/4" ballnose from BDP turning 14K at 150.
Good idea Greg! I will try that on my next piece! I having pretty good results so far but that was an issue on my Navy plaque.
I also like your idea of painting them before you cut them out. I got that stuff all over my hands (gloves) trying to paint finished shapes.
