Hello everyone! I thought I should finally start posting some things here. I have learned so much from this forum maybe I can help some other people.
I figured early on that I needed a hoist. I wanted to be able to use it one handed and be able to slide it from side to side so I could load plywood from underneath the bot and from our vertical plywood rack.
I already had the Quality vac vacuum clamp venturi pump. Then I bought a 220lb electric hoist from harbor freight for about 100.00. I picked up some super strut brace from home depot. I already had some inline skate bearings and misc. angle iron and bolts.
So far it will pick up anything I have tried to lift up to about 200lbs. The handle also swivels so if I start from the side of a sheet I can rotate it around without turning the sheet.
Enjoy! Let me know if you have any questions.
