Results 1 to 7 of 7
Thread: Build up of material on bits?
    Sep 2007
    NRC, Winnipeg Manitoba
    Default Build up of material on bits?
    Is there any type of bit or technique that prevents material from building up on a mill bit? I am basically drilling hundreds of 0.13" holes into HDPE and every 10-20 holes there is so much plastic built up on the mill bit(1/8" upcut) that it starts melting the plastic and I have to stop it to clean. By then the holes are all becoming cruddy from rewelding anyway. Then I restart and sometimes the holes are off. And either way, the surface is a mess.
    I realize that slowing down the spindle will help *some* with the melting but it won't prevent the build up of plastic and eventual heat build up.
    Any help please on techniques or special bits?
    Columbus IN
    Try using the drill geometry recommended here:
    http://www.plasticsmachining.com/mag...9/PP-HDPE.html
    Also, try peck drilling (frequently back out the bit till it clears the surface).
    Harold
    Let me DROP EVERYTHING and work on YOUR job!!
    cnc routing, portland or
    I was told doing peck drilling would help. so you don't drill the whole depth in one pass. but I had 20,000 holes to drill so it was not practical. I sprayed the surface with wd 40 as it was all I had and it took care of it.
    Winter Park FL
    If you are getting a build up of material, you might want to look at the bit you are using - is it right for the material or the speed of the router / spindle - is it the right speed for the bit and material.
    Oct 2009
    Tonasket, WA
    [QUOTE=nodnerb;98209]Is there any type of bit or technique that prevents material from building up on a mill bit? [QUOTE]
    Have you tried air? Or an air/water mister?
    Another possibility is The Cold Air Gun or Ranque-Hilsch vortex tube:
    http://www.newmantools.com/vortex.htm
    Runs off shop air but watch out for the hot end! Yoooowsers!
    Mar 2005
    Beckwith Decor Products, Derby/Wichita KS
    Sounds like you have the wrong tooling
    Try a Ons 70-500 series they are a HSS Plastic Drill designed for drilling in hard and soft plastics
    gary
    Caveco Distributor, USA
    Custom CNC Tooling/Onsrud Distributor
    Sep 2007
    Awesome! Thanks for all the replies everyone. Unfortunately the onsrud drills would not work in this case as it was a special size and I needed to 2d toolpath it. It always seems to be a special size. lol
  1. How to build really fast
    By bleeth in forum ShopBotter Message Board
    Last Post: 03-31-2013, 09:13 AM
  2. Best way to Build this Sign
    By jimmya in forum ShopBotter Message Board
    Last Post: 08-08-2012, 10:06 PM
  3. Build your own indexer for under $200.00
    By arnold in forum Indexer
    Last Post: 06-18-2010, 08:56 AM
  4. eCabs V6 build 3 is out
    By Gary Campbell in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 03-16-2010, 04:31 PM
  5. Can't Build Our Own Tables ???
    By stargategfx in forum Archives2006
    Last Post: 12-28-2006, 04:46 PM
