Thread: safe z height adjustment
    Oct 2009
    KenCraft Co Inc, Toledo Ohio
    Default safe z height adjustment
    I have a job in which I am cutting at either end of the table. I am using a piece of wood across the center of the table to hold pieces in a fixture. In Aspire it shows my safe z as .23, however my clamp sticks are 3/4". Right now the bit is plowing through the stick in the rapid move, but I think the bit will break eventually. How do I adjust the safe z? Can I adjust it for this one job. Thanks.
    Tracy Spitulski
    KenCraft Co Inc.
    PRSa 6096
    www.kencraftcompany.com
    Hardwood Lumber, Custom Millwork
    Dust Collector Fittings
    Tracy,
    In the toolpaths tab, under material setup, you can change this.
    You could also just edit the .sbp file at that point to clear the part.
    Changing it in Aspire will make all clearance moves at that height so it may take the file a bit longer to run.
  1. Estop adjustment or alternative
    By rhfurniture in forum Techniques for Cutting, Drilling, Machining
    Last Post: 03-14-2015, 07:49 AM
  2. Max Safe Z Height?
    By DanThomson in forum ShopBotter Message Board
    Last Post: 02-23-2012, 02:53 PM
  3. Is there any adjustment in the bearings
    By bcondon in forum ShopBotter Message Board
    Last Post: 03-08-2010, 07:11 AM
  4. Setting safe z height?
    By chiloquinruss in forum Troubleshooting
    Last Post: 11-08-2009, 11:11 PM
  5. Changing safe z height
    By tas99 in forum VCarvePro and PhotoVCarve
    Last Post: 04-12-2007, 07:09 PM
