I am installing my Prox. Sw. on a prs 48 48 standard and the manual says hook up to the 12+vdc... All I am seeing is 5+vdc on the board.
The little paper with the switches says 10-30vdc....
Not sure what to do?
I'm not sure what version your assembly manual is, but here is the diagram from the one that came with my 2007 PRS-standard 48x48...
That is the diagram I have also. My Board has no 12V output though... Let me take a photo...
These are all the terminals I have on the board... No 12+vdc even in the box...
Adam...
The standards that use a computer white box for a control box are 12V. All other prs use 24V for the prox
BL is Gnd
BRN is +24V
BLK is IP 2 or 3
Gary Campbell
GCnC Control
GCnC411(at)gmail(dot)com
Servo Controller Upgrades
— Albert Einstein
Thank You Gary,
Should I grab 24+ at the spindle plug or the incoming 24+ plug on the side?
Look at the alpha instructions and it shows how to hook it up with 24 volts on that system. That should work for yours. You must have one of the new std systems.
Kenneth
One word of caution, be sure the prox switch you are installing has an "Open Collector" type output. Sometimes these are labeled "NPN" output. Other types may apply the 24v to the input pin of the control board. Big risk of SMOKE then.
D
--Greg Westbrook
