What seems to be happening with the last 3-4 files is at the conclusion of the file it goes back to home (center of material) the router powers down but while it is doing that it is raising the Z to where it is topping out and falling on the finished project. This has happed at least 3 times in a row.
The last file was a simple 3d finishing pass using a 1/8th" ballnose bit carving on a 1" thick piece of walnut sitting on top of a .75 piece of mdf jig. The bit was 2"(?) and the cutter "safe Z height" was set at .10
When i C2 the Z set up to 1" above material prior to starting file. When file ends the Z goes up to 1.5" or more before it craps out and falls.
What part of the code do i need to show in order to see where the issue is because i can't recognize where the problem is.
