Hi my fellows,
Came back after long long time.... i just posting here about my Laser scanner improved hardware..
As you are well aware, i have some funky old hardware for the David Laser Scanner... I did many scan with good accuracies but the scanning setup was heavy and mobility was an issue... So i did work on following points to improve the setup:
1- It can easily perform the scanning without calibration panel.
2- It can be easily disassembled and assembled in new location.
3-Compact in size for transportation
4- Aesthetically look beautiful
5- Electronics have all the control features
6- The complete setup is light weight.
7- Accurate and reliable
After, considering all above and lot more i was able to DIY the hardware and made the first test scan.. Attached you can see the scan of spray bottle .. Total 9 scans , each scan cycle took 2minutes.. Approximate height of the spray bottle is 250mm and 80mm in diameter...The alignment and stitching was a difficult part due to symmetry in the model.. However, i learn a lot in stitching the scans...
